Auto transmission shift lever leak help A43D
Old Sep 18, 2023 | 05:19 AM
vert's Avatar
1986 22re with A43D automatic transmission. There's a leak coming from the shift lever linkage where it goes into the transmission above the pan. I confirmed that the circled area below is where the leak is coming from by wrapping a shop paper towel around the lever and it gets soaked with ATF after a couple of days. I've looked through the Toyota Shop Manual as well as the A43D Transmission Service and Repair Manual and I can't find anything that would tell me if there's a gasket/o-ring or some other part that might have failed in that area or the steps needed to fix the leak. I would really appreciate any help in diagnosing and repairing this problem.
Old Sep 18, 2023 | 06:39 PM
aztoyman's Avatar
I actually have one of these transmissions in my garage. I've only pulled the pan though so I don't know what it takes to pull the shaft. I would think that there would have to be a seal. Maybe look up a parts list.
Old Sep 19, 2023 | 04:08 AM
vert's Avatar
Looks like I need 2 new oil seals shown in the picture below. Available at NAPA and called "Automatic Transmission Seal, Manual Valve Lever Shaft - Metal Clad. Part number ATP 15234".
IvanTheTerrible87
Jun 30, 2013 04:59 PM
hoke
Oct 19, 2010 01:25 PM
Cal01
Mar 3, 2010 09:20 PM
bobben
Sep 22, 2006 01:23 PM
Krash
Dec 18, 2002 08:37 AM
