Marlin Crawler Steel Braid Clutch line on 91 3vze pickup: Will it fit?
Anyone have the Marlin Crawler Steel Braided Clutch Line installed on their rigs? My Clutch hose is leaking and I want to upgrade to a Steel Braided line. I got this one from Marlin Crawler for my truck, but when I looked at the stock fittings, their a tad bit longer compared to the MC hose fittings .
Website says its compatible: Applications include all 1979-1995 Toyota Hilux trucks and 4Runners, 1995-2004 Tacomas, and 1996-2002 4Runners. Compatible with 2WD or 4WD. Depending on application, some frame brackets have a larger opening and will require both clip shims to compensate for this extra gap. The installed photos at left are from a 1982 4WD Pickup and only require 1 clip shim as shown at the lower side of the upper frame bracket.
I don't think It'll fit unless I modify the hardlines. Anyone have this clutch line installed on their 89-95 3VZE pickups?
