88’ pickup 2WD auto leaking from rear of transfer case
Old Dec 21, 2022 | 04:34 PM
oxdave1312xo's Avatar
Forgive me if any of this is confusing, this is my first time.
there’s a significant amount of transmission fluid leaking from where the slip yoke inserts into the transfer case. I’ve seen on the 4wd models many videos of how to replace the seals behind the output shafts… but none of those are the slip yoke. I haven’t taken it apart yet, is it the same rear seal just hidden in the case? Is there something different? Should I anticipate needing to replace the yoke?
Old Dec 21, 2022 | 08:23 PM
old87yota's Avatar
If you have a 2WD Truck, you don't have a transfer case, just the transmission.
I think what you are looking at is the "Extension Housing" which is just the rear part of the transmission.
There is an oil seal in the Extension Housing that seals against the slip yoke.
Unless your slip yoke is damaged, you should be fine keeping it.
Toyota sells the seal as part of a "seal kit" that includes the oil seal itself, a dust seal (a felt-like ring), and a metal retainer.
Diagram from parts.toyota.com
SEAL KIT, OIL(FOR AUTOMATIC EXTENSION HOUSING)
Part Number:
04332-30030
https://parts.heartlandtoyota.com/p/...433230030.html
You will need some way to get the seal and retainer driven into the extension housing nice and even, keeping in mind the output shaft of the transmission sticks out decently far.
Old Dec 22, 2022 | 08:27 AM
Thanks so much. I’ve seen people using large deep sockets to drive in the seal, do you think it will need to be greased before going in?
musician235
Jul 11, 2021 10:24 AM
colorado-yota
Oct 2, 2013 07:26 PM
rdlsz24
Jun 5, 2006 05:07 PM
Bogil
Dec 4, 2005 04:24 PM
jay-q
Nov 30, 2004 01:06 PM
