Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
NEW 16-22 Tacoma Sequential LED Tail Lights | FORM Lighting
Old Oct 17, 2022 | 09:18 AM
Form Lighting's Avatar
FormerVendor
Looking to upgrade the tail lights on your Toyota Tacoma? Look no further. Introducing Sequential LED Tail Lights from Form Lighting. Not only will you stand out on the road with a more modern appearance, but you’ll add LED reverse lights, a sequential LED turn signal, and a unique startup sequence.
Modern Appearance. Unlike many other aftermarket options on the market, these tail lights were designed with factory-style optics, to diffuse the light in a smooth, even appearance. The outer perimeter of the lamps illuminates in a C-shaped bar for running and brake/turn lights. On the interior of the lamp, you’ll find a unique 4-tier LED design, for a truly distinct and premium look.
Smoked, Not Sprayed. Nightshade? No thanks. The lens on our Tacoma tail lamp is designed with tinted optical components, which provides a factory-quality smoked appearance - not a cheap painted look like others on the market.
Startup Sequence. These tail lights are packed with modern features, including a unique startup animation. Anytime the running light turns on, it will illuminate in a chasing stacking pattern that is sure to turn heads.
Sequential Turn Signal. The startup sequence won’t be the only thing turning heads. These tail lights also feature a sequential LED turn signal. Any time the turn signal is activated, the red LEDs in the outer C-bar smoothly sequence from the top and bottom, meeting in the middle for a truly premium look.
OEM-Grade Construction. Form Lighting tail lights are built with quality in mind and constructed using OEM-grade materials, including a UV-coated polycarbonate lens, automotive-grade LEDs and optics, and direct-fit connectors. While they may not be the cheapest option on the market, the fit and finish of our lamps are superior to other aftermarket units.
Road Legal. The smoked lens color illuminates with red LEDs, and features an integrated retroreflector sidemarker and running light, just like the factory lamp. These lamps are SAE and DOT-compliant for on-road use.
Plug-and-Play. Our tail lights for the Tacoma are plug-and-play. They will fit perfectly, without any body gaps. Installation is a breeze and can be done in under 10 minutes. Unlike other options on the market, these tail lights are also fully compatible with Tacoma’s blind spot detection system, if you have it. There are no blind spot system errors, flickering, or hyperflashing!
Click the video below to see HOW to install our 2016-2023 Toyota Tacoma Sequential LED Tail Lights!
Two-Year Warranty. All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. The warranty is supported directly by Form Lighting, and any replacement parts, if needed, are shipped quickly from Form Lighting’s US warehouse. On the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return usually is necessary.
Do you have additional questions? We’ll be happy to help!
• Reply to this thread
• Send us a direct message
• Email: contact@formlights.com
Are you a US forum member? DM us for a FREE shipping code!
Jordan M.
FORM Lighting
Old Dec 22, 2022 | 10:01 AM
FormerVendor
ONE. MORE. SALE. 🏷
Now through 1/5, you can get 15% OFF all FORM Lighting products exclusively through Amazon and our authorized dealers.
This sale includes our new LED tail lights for the 16-23 Tacoma, which just started shipping this week!
Shop our Amazon store ➡ Form Lighting
Old Jan 2, 2023 | 11:03 AM
FormerVendor
There’s only a few days left to save!
Through midnight 1/5, you can get 15% OFF all FORM Lighting products exclusively through Amazon and our authorized dealers.
This sale even includes our new tail lights for the 16+ Tacoma, which started shipping this week!
Shop our Amazon store ➡ https://amzn.to/3WlDQcv
Old Jan 5, 2023 | 10:26 AM
FormerVendor
Last chance everyone!
Through midnight TONIGHT, you can get 15% OFF all FORM Lighting products exclusively through Amazon and our authorized dealers.
Don’t miss out on this great chance to pick up some fresh new lights!
Old Jan 17, 2023 | 12:10 PM
FormerVendor
Check out this review and installation video of the new Form Lighting 16+ Tacoma Tails!
Shoutout to Rich of Tacoma Network for putting this together!
Form Lighting LED Tail Lights - Toyota Tacoma 3rd Gen. - Install/Compare
Old Feb 1, 2023 | 11:38 AM
FormerVendor
New Year, New Lights! 😎
Check out our YouTube channel to see more!
Upgrade Yours Here!
Old Mar 6, 2023 | 12:54 PM
FormerVendor
The lowest prices of the season are HERE! 😱
Now through 3/13, you can get 10% OFF SITEWIDE at FormLights.com.
If you’ve been waiting for the best time to pick up a new set of tail lights, the time is NOW!
Click here to save!
Old Jun 1, 2023 | 07:49 AM
FormerVendor
Have you been thinking about upgrading your tail lights? NOW is the time to save BIG!
Memorial Day Savings are here at Form Lighting, which means through June 2nd, you can get 10% OFF sitewide.
Get yours before it's gone! ➡ https://www.formlights.com/
Old Jun 14, 2023 | 09:49 AM
FormerVendor
https://www.youtube.com/shorts/FDHSGC3YwX0
From front to back, we've got your 16+ Tacoma covered. 👊
Upgrade Yours Here!
Old Jul 3, 2023 | 11:55 AM
FormerVendor
If you've been waiting for the best time to upgrade your headlights- the time is NOW! 📣
To celebrate Independence Day we are offering 10% OFF SITEWIDE through July 7th. Plus, get a free FORM t-shirt with any purchase! 🎆
Get Yours Here!
Old Jul 7, 2023 | 06:10 AM
FormerVendor
The best time ⏳ to upgrade your taillights is almost UP!
10% OFF sitewide ends soon! Get over to the site now to save up to $100, and don't forget with every purchase you will receive a free FORM t-shirt!
Get Yours Here!
Old Jul 7, 2023 | 06:13 AM
FormerVendor
https://bit.ly/3YSCJ5C']Get Yours Here!
Old Jul 11, 2023 | 09:11 AM
FormerVendor
The Prime time to Save is NOW ❗
For two days ✌ only 7/11-7/12 Save 10% on all FORM products.
Get Yours Here!
Old Aug 31, 2023 | 10:07 AM
FormerVendor
Summer temps are cooling down, but our deals at FORM are just starting to heat up! 🔥
NOW through Friday 9/8 save 10% on all FORM Lighting products.
That includes our headlights for the 07-13 Silverado!
Check it out here
Old Sep 8, 2023 | 10:05 AM
FormerVendor
The time to save is almost up!
You have until midnight tonight 9/8 to save 10% on all FORM products!
Including our tail lights for the 16-23 Tacoma!
Check them out here!
Old Nov 7, 2023 | 07:08 AM
FormerVendor
Check out our NEW YouTube video covering the best lighting upgrades for your 2016-2023 Toyota Tacoma! 🤘💪
Old Dec 1, 2023 | 11:04 AM
FormerVendor
Our BIGGEST sale of the year ends tonight at midnight! 😧
Your last chance to save 15% on Headlights and Tail lights for your Tacoma is NOW!
Don't miss out. Take advantage of these sweet deals while you still can!
https://www.formlights.com/by-vehicl...ta/tundra.html
Kaleo1
Apr 10, 2017 08:41 PM
Blackbird
Nov 6, 2009 05:30 PM
86blue4runner
Dec 26, 2008 12:26 PM
cweich
Feb 12, 2008 06:19 AM
rearviewmirror
Mar 1, 2006 01:49 PM
