86 Pickup: Unplugged component by Trans Speed Sensor
Old Sep 23, 2022 | 11:14 AM
chillllama's Avatar
I tried searching through the forums and online for diagrams, but am running to a dead end. There's something unplugged from the same wiring cluster that the speed sensor connects to by the intake. Can someone let me know what this may be? Thanks!
Old Sep 23, 2022 | 12:31 PM
2ToyGuy's Avatar
Could be the wire for the 4WD light? There's a switch in the transfer case that makes when you go into 4WD, and turns on the green indicator light on the dash panel. Having rambled for so long, it strikes me you didn't specify whether you have 4WD or not. If you don't, it could be that the wire for the light is present in the wiring harness, but if you don't have 4WD, it may not be used? Same wiring harness as the 4wd version, just used in the 2WD version. It may have come with a cap to cover it in that case, but that's a harsh environment down there. The cap may well have vanished years ago.
Then again, I may be totally off in left field someplace. Totally wrong. Maybe.
Pat☺
Old Sep 23, 2022 | 01:00 PM
chillllama's Avatar
Thanks Pat! It is a 2wd model so I think your theory may be correct. I appreciate the response.
Bill Lowry
Jan 22, 2022 08:10 AM
krusty_45
Nov 6, 2015 01:28 PM
Takenover
Jan 30, 2010 12:19 AM
J.E.L
Apr 5, 2009 10:59 AM
BAMF_3521
Oct 16, 2008 11:03 AM
