Broken Bump Stop - 91 4Runner
Old Jul 14, 2022 | 06:09 PM
RKGraves's Avatar
'91 4Runner 4-WD - Broken Bump Stop.
While replacing the rear shocks I noticed the passenger-side Bump Stop has broken off and is laying loose inside the coil spring (see picture). In checking the driver-side - it is still attached but not securely. How is the best way to repair this?
Thank You for Your Help!
Randy Graves
N.Idaho
Old Jul 15, 2022 | 07:27 PM
RKGraves's Avatar
*** Update ***
Found this video helpful - 2nd Gen 4Runner Overload Bumper Repair
It clearly demonstrates the problem and how this gentleman made the repair (nicely done!). I do not have a welder or yet know how to weld. Considering as an alternate solution to drill a hole in the top-center of the upper coil spring mounting bracket and run a bolt all the way through and out the top. I have access to the area between the top of the rear coil spring and the body of the vehicle - pretty good access!
I want to keep this tread active as I'm sure other 2nd Gen 4Runner owners have experience the same problem, and hopefully some will share their solutions.
Thank You!
Randy Graves
N. Idaho
'91 4Runner, V6, 5spd, 4wd, 194K miles
newjerseyredneck
15
Jan 2, 2013 10:04 AM
DetroitStyle
Jan 22, 2012 09:38 AM
turbowhine
Feb 14, 2010 01:25 PM
celica
Nov 8, 2007 07:04 PM
JEDI87
Apr 26, 2006 10:12 PM
