Posible bent connecting rod?
First off, did you stop turning the crank when the timing mark lined up or did you stop when the piston was at its highest point?
second, piston height effects compression ratio, so if it is indeed sitting lower in the bore than the others it should have lower compression as well.
engineerjoe
Jun 27, 2007 08:21 AM
