1992 Toyota Pickup 4 Cyl PU
Old Dec 2, 2021 | 06:54 AM
Gatz101's Avatar
Hello everyone! Happy Thursday! I wanted to get some feedback about a leak Ive been having. I posted something months ago regarding a power steering hose and a leak from the existing one. I discovered that a heater hose wasn't good enough so I replaced it with a hydraulic hose. Since then I have discovered a slow leak from the power steering pump to the reservoir (so the return). When I replaced the hose and I used the cheap auto part store screw clamps. I then thought to use the original ring pressure clamps after I discovered a small leak. It still leaks, seemingly from under the hose. When I inspected the hose there were no cracks. There was a small imperfection in the cut of the hose where the hose marries the pump far past where it joins. I used a small mirror to try to find a leak. I noticed that maybe the pump has a sort of weep hole...is that true? If so, is there a quick easy fix?
TheBoiKing
Jan 27, 2021 08:49 AM
johnny13
Mar 21, 2015 03:56 PM
AustinTaco
Jan 6, 2014 11:36 PM
BlackBox
Jun 17, 2010 01:16 PM
iamsuperbleeder
Jan 6, 2010 06:15 PM
