Looking for 2.4 Diesel information
Old Sep 19, 2021 | 10:16 PM
STERFRY333's Avatar
Greetings!
I just picked up a 2.4 2L (non turbo) diesel out of an '84ish 2WD toyota truck. I plan on swapping it into my '86 4runner to replace my worn out 22r.
I was able to pull everything in the engine bay including the fuel filter and what looks to be an external oil filter. I also got the entire truck wiring harness and the bellhousing. I don't know very much about diesels and am looking for any information I can. The truck was running and crashed into a tree, so I know the engine is fine, but I will be pulling the head and taking it to a machine shop.
I am also not sure how I will get the power steering to work as the diesel has the pump and reservoir on the passenger side. Also there is a weird looking pump on the back of the alternator I am also unsure of but it has hoses going into the block like it's some sort of oil pump. Any rebuilding material and diagrams would be nice.
Old Sep 19, 2021 | 10:18 PM
STERFRY333's Avatar
Also how would I wire up the tach?
Old Sep 20, 2021 | 08:23 AM
slacker's Avatar
pump on the alt is for vacuum
I do have a toyota manual for the 2L if you need some specs or maybe some diagrams
Old Sep 22, 2021 | 11:19 AM
STERFRY333's Avatar
Sweet yeah I was just looking for the diesel line diagram and bolt torque specs for the head and crank and such.
theres 2 lines going into the injector pump and I’m not sure which ones the input and which ones the output. Also would I need a lifter pump for the tank?
Old Sep 23, 2021 | 09:02 AM
slacker's Avatar
fuel line ?
and specs
File Type: pdf
Old Sep 23, 2021 | 09:05 AM
slacker's Avatar
try this again
Old Sep 24, 2021 | 11:55 AM
STERFRY333's Avatar
fuel line ?
and specs
awesome thanks. Yes the fuel line. On the injector pump there is a line going into the back of the pump, as well as one on the front.
Old Sep 25, 2021 | 08:09 AM
slacker's Avatar
kzunell
Jul 31, 2013 04:26 PM
vic.kulla
7
Jul 10, 2009 08:37 PM
inh0001
Jan 9, 2009 04:06 AM
treadtastic
7
Jul 23, 2008 06:21 PM
surfmobile
Apr 28, 2006 03:45 PM
