First Gen 4Runner Bumper/Hitch options
Howdy! Longtime listener first time caller
I have an 86 4 cyl 4Runner that I need to get a rear bumper for. I don’t need a beastly crawler situation, just for mild off-roading. Wondering what options folks have found for under $500. Ideally I’d like it to be strong enough to give me a buffer if I’m rear ended and either have a built in hitch receiver or ability to mount one on or around it and take a bit of vertical weight (300-400 lbs?). Thinking about attaching a cargo carrier basket for more space inside the car for sleeping. Any thoughts or advice welcome. Thanks!
…I have an 86 4 cyl 4Runner that I need to get a rear bumper for. I don’t need a beastly crawler situation, just for mild off-roading. Wondering what options folks have found for under $500. Ideally I’d like it to be strong enough to give me a buffer if I’m rear ended and either have a built in hitch receiver or ability to mount one on or around it and take a bit of vertical weight (300-400 lbs?). Thinking about attaching a cargo carrier basket for more space inside the car for sleeping. Any thoughts or advice welcome. Thanks!
4xinnovations is the only (or, at least was several years ago when I bought mine) off road style bumper with high clearance and wraparound protection that has a receiver that is actually rated to tow.
I have a trail-gear bumper and bought the reinforcements that attach to the side of the frame. Being that the bumper also mounts into the same exact location as the hitch, i don't see a problem with towing anything, if you need to.
Sweet, thanks for the info! The trailgear bumper definitely seems like the most affordable option. I don't see options for side mounts... Does that help disperse the load or something? Have you had any experience towing with it?
RockyWA
13
Dec 5, 2008 02:29 PM
89-4run
10
Jun 18, 2007 06:14 PM
LittleRedToyota
Jul 14, 2005 03:13 PM
