Wooo Hooo! S/C Installed!
I'm sooo pumped, I installed my S/C by myself yesterday. I took my time and it took about 5 hrs. Took me over an hour just to figure out the vacuum routing,
but I apparently got it right on my first try. Still need to clean the hoses up though, figured I drive around to see how everything holds up before I put the final touches on. I pulled off the whole thing for under $700 bucks. That included the used charger, replacing all the nose drive bearings myself, oil, etc.
I definitely notice a big difference in power, but I am getting a little cough when I punch it, and the tranny seems a little confused on where to shift. I figure it'll take the ECU a couple hundred miles to adjust. The sound it makes is a litlle more weeny sounding that I was expecting, I was thinking "turboish", not "bee stuck under the hoodish" but its still cool.
Just thought I'd share
Now I gotta get that tranny cooler installed...
but I apparently got it right on my first try. Still need to clean the hoses up though, figured I drive around to see how everything holds up before I put the final touches on. I pulled off the whole thing for under $700 bucks. That included the used charger, replacing all the nose drive bearings myself, oil, etc.I definitely notice a big difference in power, but I am getting a little cough when I punch it, and the tranny seems a little confused on where to shift. I figure it'll take the ECU a couple hundred miles to adjust. The sound it makes is a litlle more weeny sounding that I was expecting, I was thinking "turboish", not "bee stuck under the hoodish" but its still cool.
!Now I gotta get that tranny cooler installed...
im so jealous. you pulled it off so cheap too.
i just cant throw down 4grand to have an s/c w/full install and im not good enough at engine mechanics to be able to install myself.
i should start ebaying all my useless junk to raise money or something...
I was going to tell you .. I believe you can get the brackets for the OEM (hella micro de) foglights and use those to put your fogs back in the stock location on the 99+ bumper. If not .. it shouldn't be too hard to fab up a small bracket .. the bolt holes are already there
Originally Posted by MTL_4runner
If that is your truck in the avatar, doesn't it have a brushguard too?
Originally Posted by SLC Punk
I thought the S/C would sound turbo-ish and was shocked at the sound that it actually makes.
My wife said it now sounds like a remote control car!
You could try the ISR mod to give a more throaty sound if you haven't already.
Originally Posted by Gadget
Welcome to the club!
When you are ready to get rid of that cough, let me know.
Gadget
Gadget
When we get back from Europe this summer, that's going to be the first thing on the list.
After another putting another 100 miles on the cough is definitely not getting better, or worse. Just a little annoying when you stomp it REAL hard. sdastg1 - I'll try to get some posted tonight, got the camera with me today.
MTL_4runner - Just curious, I heard that ISR or deckplate with S/C and stock fuel system could cause more lean out, so I have my deck plate in right now. Would I be safe to open it up again??
It does sound pretty good with the dual exhaust and all, but I'll try anything to make it sound a little better.Thanks Guys!!
[QUOTE=yoda-g2]When we get back from Europe this summer, that's going to be the first thing on the list.
Yoda-g2, Im not sure if this is the same thing youre describing but check out this link--> https://www.yotatech.com/forums/show...flooring+s%2Fc
After another putting another 100 miles on the cough is definitely not getting better, or worse. Just a little annoying when you stomp it REAL hard. Yoda-g2, Im not sure if this is the same thing youre describing but check out this link--> https://www.yotatech.com/forums/show...flooring+s%2Fc
Just my $0.02 tho.
