Checking RPM with multimeter?
Old May 3, 2021 | 04:26 PM
outatime's Avatar
Hello!
I searched and searched, probably drove right past it, but I’m trying to figure out the correct procedure for using a multimeter to test RPM. Com to ground and red to distributer negative? I’m looking to get a multimeter with an RPM function and just wanting to know the right place for the leads.
86 4Runner.
thanks!
Old May 3, 2021 | 06:29 PM
Melrose 4r's Avatar
5 Year Member
I know those are the correct connections for my old “engine analyzer” box with tach and it works on my 86 22re.
i have not used a multimeter with freq counter for this though..
Old May 3, 2021 | 07:54 PM
az4x4runner's Avatar
I've used a meter with tach/dwell/volts. It needed power from the vehicle though so it had pos/neg/tach connectors. I guess you'll need a ground and then you can pick up the tach RPM signal from the IG port next to the under-hood diagnostic port.
Old May 4, 2021 | 02:11 AM
snippits's Avatar
Originally Posted by outatime
Hello!
86 4Runner.
thanks!
That's what my Actron hand held meter says to do on page 11.
File Type: pdf
Dkeith
Sep 3, 2019 12:19 AM
bthompsonwyak
Oct 21, 2013 07:46 PM
bshow
Oct 28, 2007 07:50 PM
