O-rings in headgasket kit
So I'm the middle of headgasket replacement on my 1993 22re and there are 4 small O-rings included in the Felpro headgasket kit. What are they for? Are they for the fuel injectors?
When I replaced the head gasket on my 87 4Runner, I used a FelPro gasket set. It came with all 3 rubber items for each injector. The gaskets all fit fine. Are you sure you didn't get the new grommets and "cushions" (what Toyota calls them in the FSM), as well as the 4 o-rings? If not, you might consider it. How old are the ones that came out, after all.
Don't forget to wipe the o-rings with a thin coat of gasoline when you put them on the injectors. Put the injectors into the delivery pipe before they dry out. I used a small bowl and soaked the o-rings, grommets and cushions before I installed them all. It seemed to work well. It's lasted a bit more than 20 years since then with no leakage. I'm guessing I did something right during the whole process
Good luck to you!
Pat☺
Good luck to you!
Pat☺
Thanks for the replies Gents. I went out to the shop and pulled the injectors and the o-rings are for them however there are no grommets in the gasket set. As ya'll have said the grommets are in bad shape so I've got a rebuild kit on the way. Surprisingly the o-rings are in good shape but the grommets were rock hard and brittle. Took some time and patience to get the bolts that hold the rail to the manifold they were stuck good and if a fella had just laid into them I'd bet both of them would have broken.
CanSurviveIt
Mar 15, 2009 12:45 PM
4x4Lamm
14
Jan 31, 2008 07:39 PM
northtorrey
May 31, 2007 12:42 PM
