Shocks shocks shocks
Old Feb 25, 2021 | 03:15 PM
93_4x4's Avatar
So I need a good pair of off-roading shocks, that will be capable of holding around 900lbs in the rear. Any good recommendations?
Old Feb 25, 2021 | 03:56 PM
muddpigg's Avatar
I’m a fan of Bilstein.
as for holding 900lbs in rear that is going to be springs not shocks. Chevy 63s are a awesome but I Offroad so load carrying capabilities are low on priority list. But they do well with 4rnr extra weight, spare, tools, fluids, camping gear, and cooler. And still Offroad awesome while loaded.
Old Feb 25, 2021 | 09:21 PM
RAD4Runner's Avatar
Originally Posted by muddpigg
...as for holding 900lbs in rear that is going to be springs not shocks. ...
And do not forget to make sure your shocks compress and extend same as, if not more than, your springs compress and extend.
Old Feb 26, 2021 | 07:48 AM
MaK92-4RnR's Avatar
1) Are you lifted?
2) Why are you carrying 900 lbs?
Old Feb 26, 2021 | 10:07 AM
93_4x4's Avatar
I believe I just have the factory 4x4 lift. I'm running R16 with 33in tires on it. I want to put a pop-up camper slide in, in the back of the truck and so thats going to weigh like 900 lbs at most.
Old Feb 26, 2021 | 10:18 AM
MaK92-4RnR's Avatar
1) No such thing as an OEM lift kit for the IFS. Can you post a picture of the front end of your truck?
2) Old Man Emu makes a heavy duty leaf pack for these trucks. No idea if it's rated for that kind of weight, though. I'd assume it would be?
3) Everyone i know with cab over/slide in campers has had helper bags installed on their rigs to help with the additional weight.
Old Feb 26, 2021 | 12:18 PM
93_4x4's Avatar
pictures
1. I dont think I have IFS but I could be wrong.
2. What are helper bags?
3. Pictured are my springs.
Old Mar 4, 2021 | 07:02 AM
rattlecanpaint's Avatar
So, 1.) You DO have IFS. That stands for "Independent Front Suspension." It doesn't have a solid axle like the rear.
2.) Helper bags and basically Air springs that would be installed on the top of the spring in the center (Where the axle is located) and then mounted on the top side to the frame. You inflate them to increase your load carrying capability. These work great in that when there's no load you can deflate them some and they won't ride horribly. A replacement leaf spring designed to haul extra weight like you want will ride very harsh without that weight.
3.) Those appear to be factory springs. I.e. They're going to sag with 900lbs in the back.
Old Mar 4, 2021 | 12:20 PM
Blueman's Avatar
I know you're looking for rear-shocks with some suspension lift, but if you want some [nearly] new front shocks for *free*, just let me know. KYB Monomax 565058 -- they were too stiff for my '87 that sees mostly pavement these days so I took them off after not many miles, but they might make sense for a truck like yours with heavier loading. Anyone who wants them can have them for free (or shipping cost).
RogueYota
Mar 5, 2012 09:28 AM
hyzerponix
Dec 6, 2010 07:00 AM
SR5
Feb 11, 2009 04:05 PM
JohnnyRanger54
Feb 11, 2008 06:18 AM
ivanr
May 27, 2006 12:57 AM
