Rear Suspension question
Old Jan 4, 2021 | 07:58 PM
SideSwipe's Avatar
i was thinking about getting 3” blocks for the rear of my 1986 4runner to accommodate 33” M/T’s but i was wondering if at that point i would have to go with different shocks or if the stock height shocks on there currently would work with that height adjustment
thanks in advance
Old Jan 4, 2021 | 09:11 PM
RAD4Runner's Avatar
thanks in advance
Why not a proper spring lift? Or at least the Zuk mod with springs that would lift it and improve ride quality?
No, stock shock would not be long enough. A friend's friend's snapped both shocks on same wheeling trip for that reason.
Old Jan 4, 2021 | 11:52 PM
SomedayJ's Avatar
Delete.
Old Jan 4, 2021 | 11:57 PM
SomedayJ's Avatar
I believe you'd need new shocks.
I have the Zuk mod in my 4R with 33". I don't have problems with it, but @wallytoo commented about the possibility of snapping the brake lines if the springs get lose. As far as I know, there is not reports about something like that happened, but made me think about it.
Old Jan 5, 2021 | 03:54 AM
87-4runner's Avatar
Zuk mod and Bilstein shocks, great ride and no issues for 7 years...33s fit nicely
Old Jan 5, 2021 | 07:48 AM
SideSwipe's Avatar
Did you use the 12” or the 14” springs? im shooting for about 3” of lift in the rear so from what i see i should go with the 12”. 14” seems to give about 4.5” of lift. this deff seems like the better way to go now that im looking into it
Old Jan 5, 2021 | 08:06 AM
SomedayJ's Avatar
I installed in mine Black Magic coil springs, 5" x 12" 125 lbs.
The way it looks with the zuk mod and the 33" tires:
Old Jan 5, 2021 | 08:27 AM
87-4runner's Avatar
ditto nice rig
Old Jan 5, 2021 | 10:20 AM
SideSwipe's Avatar
Yeah this is what im looking for right here. You dont happen to have a link to the springs you bought do you? i googled and couldnt find any. Links on Zuk’s website were all expired.
Old Jan 5, 2021 | 01:18 PM
87-4runner's Avatar
https://www.southwestspeed.com/?sec=...AGIC%20SPRINGS
Old Jan 5, 2021 | 01:36 PM
SideSwipe's Avatar
thanks 87 ur the man
Old Jan 5, 2021 | 01:44 PM
5 Fists's Avatar
There are certain years of Jeep TJ coils that will work as well, the ones I used were front coils off a 2001 TJ I think. Year could be wrong. The bottom of the coil reduces down to around 2.5", which sits around the rubber bump stop rather nicely, and the top is about 5" which fits around the metal U on the frame nicely. They came about 16" long, and I cut them down to 13" to get my rear back up to slightly over stock height.
I had about 1.5" between bump stops before adding coils.
Old Jan 5, 2021 | 03:33 PM
wallytoo's Avatar
my rubber bumpstops on my #1 '87 are gone, which means i'd have to replace them to make the zuk mod work. i replaced the springs in 2013 with oem-style springs from sd springs in penn. they are sagging a bit now 7 years later - i might go with the chevy springs next.
Old Jan 5, 2021 | 06:33 PM
SideSwipe's Avatar
@87-4runner Those South West Speed spring taper down at the bottom like the photo that was posted above right? Because they only offer the 5” O.D size springs which will go around the upper bump stop and would have to narrow down at the bottom to fit on the lower bump stop. Theres no pics on their website
Old Jan 5, 2021 | 10:09 PM
SomedayJ's Avatar
EBay, it was a few years ago, I can't see them in my purchase history anymore.
Anyway, I found these ones but they are 13", you can try them like that. If they are long for your truck you can cut them later:
https://www.ebay.com/itm/NEW-RACING-...wAAOSwD0VZ0nPk
Old Jan 5, 2021 | 10:21 PM
RAD4Runner's Avatar
...Those South West Speed spring taper down at the bottom like the photo that was posted above right? ...
For No-Cut, No-Weld zuk like Someday's and 5Fists, springs are tapered like on 5Fists photo:
... possibility of snapping the brake lines if the springs get lose.
My solution to that is capture screws on the upper bump stop. I did not know about the tapered springs so I cut my upper bump stops to use straight springs. I used 12-inch 125lb springs and I believe they restored stock height. Top of leaf pack rom frame went from 7.75 inches to 10 inches.
RETAINING SCREWS
TWELVE-INCH, 125-POUND BLACK MAGIC SPRINGS
TOP OF LEAF FROM FRAME BEFORE ZUK: 7.75 INCHES
TOP OF LEAF FROM FRAME AFTER ZUK: 10 INCHES
This is with the truck empty. I'm guessing 13-inch or 14-inch @125-pounds/inch springs would give you around 2-3 inches lift from stock.
Old Jan 6, 2021 | 06:44 AM
87-4runner's Avatar
I just took my wheel cutter and cut off the very bottom of the upper bump stop bracket, then used a large Cresent wrench to spread them enough to get the springs in... no need for retaining screws.
mind you, they do make some strange noises til they get seated good
we had another 87-4runner i did the zuk mod to the same way nearly 20 years ago still sets level and never been any issues
Back then.... daughter was in high school and we were ready to go on a basketball trip from Oklahoma to Illinois for a summer league tournament.
Today... gave this one to our daughter, (she doesn't get the turbo 4runner) lol drove it during her college days and wanted it.
Old Jan 6, 2021 | 06:52 AM
SideSwipe's Avatar
On these in the pic they dont taper on either end so they wont work on the bottom bump stop right? you need one straight end and a tapered end for the 5” to work i believe
Old Jan 6, 2021 | 06:54 AM
87-4runner's Avatar
Those WILL work. You can see from Radrunners pic they fit fine over the lower bump stop.
Old Jan 6, 2021 | 07:00 AM
87-4runner's Avatar
You just have to jack the truck up by the frame so the axle will drop down enough to get the springs in place.
