I bought an old 87 4Runner a while back in in non running condition. Cleaned the tank and bought a new fuel pump. Fuel pump wouldn’t run on the key so I jumped it and got the truck to run. It sounded like a box a rocks though. So I pulled the motor had it machined and I rebuilt it. I just finished everything up today and have been messing around with it.
I bought the Bosch 4 hole spray injectors. They came with a splice to replace the resistor box.
My issues are:
#1 why am I having to jump the relay to run my fuel pump. What Components do I need to check?
#2 why am I having to pop it with ether to get it started. Cold start injector and timing switch worked when I first fired it off 2 or 3 times before the rebuild and new injectors.
has anyone else ran the Bosch injectors and ran into a cold start issue?
