Grinding after new brakes.
Old Nov 25, 2020 | 07:21 PM
Back to the Future's Avatar
1992 Extracab DLX, 22re, 5 speed.
After quite a bit of researching, I can't seem to find anything that seems to be similar to my situation.
So, I replaced the front rotors, calipers, and pads. Re-packed the inner and outer bearings. Right front hub would not spin with the old caliper on. Took it off and the hub spins freely. So bearings ruled out as culprit it seems. When I put the the new pads and caliper on with the caliper bolts barely tightened the hub spins freely. When I tighten the caliper bolts all the way down the hub becomes frozen and will not spin. It doesn't look like I have contact with the dust shield. Any ideas?
Old Nov 25, 2020 | 07:30 PM
muddpigg's Avatar
Would help to have pics from multiple angles. Sounds like something is not aligned properly, like duh sure you thought of that already.
curious to see view from over caliper looking towards rotor
Old Nov 25, 2020 | 07:35 PM
5 Fists's Avatar
I believe the V6 rotors are slightly wider than the 4 cylinder, is it possible you ended up with the wrong rotor so your caliper doesn't have clearance?
Old Nov 25, 2020 | 08:02 PM
akwheeler's Avatar
Can you bolt the caliper on without the pads in it or does it drag then as well?
not part of your issue, but the anti rattle spring is in wrong, must be wrapped around one of the pins or you'll lose it.
Old Nov 25, 2020 | 08:16 PM
Will take more pics when I take the wheel off.
Old Nov 25, 2020 | 08:17 PM
The rotors were the same size as far as I can tell.
Old Nov 25, 2020 | 08:20 PM
Thanks. The pads aren't contacting the rotor. It's only an issue when I tighten the caliper bolts all the way down.
Old Nov 27, 2020 | 11:30 AM
Well...figured it out. I'm a dumbass. I installed the pads incorrectly. Fixed that and now she's good.
Old Nov 27, 2020 | 01:29 PM
akwheeler's Avatar
So, here's a tip for all, bolt your caliper on first, then install the pads. Also, put the anti-rattle spring on before inserting the last pin and make it go through the loops in the spring.
siZors
Oct 26, 2020 05:40 AM
skoti89
Sep 7, 2011 11:57 AM
Toyomo
Feb 22, 2010 10:04 AM
truckmike26
Jul 19, 2005 04:08 PM
Eighty7ToyTruck
Mar 27, 2003 03:17 PM
