Why did I think of this sooner?
Old Jul 11, 2005 | 04:57 PM
truckmike26's Avatar
This is from the deptpartment of "Why didn't I realize this sooner?" I was doing the brakes this weekend and the vise in the basement was busted plus I forgot to bring home the portable vise bench from the shop and fumbled around for half an hour trying to clamp/secure the hubs to a wobbley table. Then, duh, to mount the new rotors/pack the bearings/install the new seals, I just flipped the tire over and presto.
Attached Thumbnails Why did I think of this sooner?-brakes-001.jpg   Why did I think of this sooner?-brakes-002.jpg   Why did I think of this sooner?-brakes-003.jpg
Old Jul 11, 2005 | 05:07 PM
FingerMan20's Avatar
That's a good idea... When getitdone and I did my brakes, I (like a friggin' moron)just sat the hub assembly on the ground to put on the new rotors. It worked, but I messed up two of the lugs on my front pass. hub and now I need to replace the studs... But it is such a PITA!! Might as well rebuild the manual hubs and re-pack (again)the front hub assemblies while I'm at it!
Donny
Old Jul 11, 2005 | 06:39 PM
I should mention what precipitated this. A "factory trained" Toyota technician impact-wrenched the front wheels back on at 6:07 pm on a Friday, warping the rotors. Yeah, I coulda brought it back and complained but the last thing I want is the same disgrunted tech thrashing on my truck again. Plus, some the caliper's pistons were siezed. So I went whole hog. New calipers, pads/shims, rotors. Seals. Hardware. Degreased everything. Repacked. I just touch the pedal, and it stops on a dime and doesn't pull to the right anymore. Oh, and I'm NEVER using cross-drilled rotors on any vehicle. The only way to true them is on flywheel machine, which is more expensive than buying new ones. And cross-drilled rotors are way more sensitive to warping. After all, rotors are heat sinks. It's just not economical for daily drivers/people on a budget.
Old Jul 11, 2005 | 06:46 PM
jimbo74's Avatar
i just unbolted mine when the hub was still on the car with an air wrench
Old Jul 11, 2005 | 06:57 PM
You probably don't have those dust/splash shields on so yeah, that's possible.
Old Jul 12, 2005 | 02:39 PM
van7559's Avatar
hey truckmike26 yo got any pics of your homade intake?
Old Jul 19, 2005 | 04:08 PM
Yep. I used a Vibrant 45-degree tube, meter adapter and silcone coupling.
user 82300
Sep 2, 2015 08:31 PM
Jmiller1023
23
Aug 6, 2015 07:03 PM
