Replacement fuel hose for 22re
Old Jul 17, 2020 | 10:54 AM
FjordWarrden's Avatar
Question Replacement fuel hose for 22re
So I had my old 1987 22re rebuilt,(by Yota1 in Modesto) but when I was pulling it I foolishly damaged the soft fuel hose that goes from the fuel supply hard line to the "IN" side of the fuel filter. I have looked in vain for replacement, but seeing as the part was discontinued many moons ago, I can't seem to find one any were. Does anyone know of an alternative? I tried finding one for the second gen 4runner but those to seem to be gone with the wind. What about one form a 2rz or 3rz? I wonder if the fittings are the same sizes.
SIde note: in case anyone is wondering Yota1 is a fantastic shop, not a lot of info on the forums about them, but they build a great engine and run a very comprehensive shop.
Old Jul 17, 2020 | 11:30 AM
2ToyGuy's Avatar
Is there anything special about it, or is it just a piece of rubber fuel line, running from fitting to fitting?
In other words, is it a special, fitted, piece? Are the fittings it connects to permanently installed somehow, or does it push on, and have clamps to hold it?
If there's nothing super special about it, why not just go get a length of fuel line from an auto parts store, cut it to fit, and slide it on?
Can you post a picture of the piece you're concerned with? It would help us help you. A lot...
Pat☺
Old Jul 17, 2020 | 12:11 PM
millball's Avatar
Reusable Aeroquip banjo fittings and appropriate fuel injection rated flexable hose.
Old Jul 17, 2020 | 12:26 PM
The line on question has a threaded femal fitting on one end and a bajo bolt "eye" on the other, both are permanently affixed.
Connects to fuel hard line from pump
Bajo fitting to fuel filter inlet.
Old Jul 17, 2020 | 12:33 PM
millball's Avatar
It is possible to cut/ grind that factory crimping tin off the original ends, to get down to the actual hose barbs that are on the fittings, and install suitable new hose with screw clamps.
I'd use the small clamps and double clamp each fitting.
Not the equal of the Aeroquip fittings I referred to previously, but substantially cheaper.
Old Jul 17, 2020 | 01:44 PM
I just cut of the original ferrules, with minimum damage t the barbs. I'll see if I can make it work with EFI hose and claps. I'm wondering If I could have a welding shop clap on new ferrules?
Old Jul 17, 2020 | 02:44 PM
So I called Toyota and confirmed that there is no replacement for this available, so don't break one! I did get a reference to a shop that specializes in hose repair and fabrication. They said that they could find a way to get it back together. The banjo fitting is not an issue as they are fairly standard, but the female end is a specialty part. So we shall see what they come up with. They may have to braze on a new barb that will accept a standard crimp ferrule. all in all it will probably cost less than an OEM part.
Old Jul 17, 2020 | 06:23 PM
swampedout's Avatar
5 Year Member
You could get a different fuel filter and skip all the custom work
Old Jul 17, 2020 | 06:25 PM
I would still need to get fuel from the main line to the filter and that requires the particular threaded fitting, that is proprietary to Toyota.
Old Jul 18, 2020 | 07:53 AM
rsmdon's Avatar
Look at off road solutions. Something he makes may work.
Old Jul 18, 2020 | 09:19 AM
swampedout's Avatar
5 Year Member
I was suggesting an aftermarket filter that would have a more common fitting
Old Jul 18, 2020 | 12:49 PM
The fitting on the filter is not the problem, banjo fittings a very common, its the comnection on the end of the hard line thats problematic.
Old Jul 18, 2020 | 12:52 PM
Ill checknout off road solutions, I did see a extend line made fornthe 3rz swap that would work, although its $90, thats more than the custom repair job. Also Nick at Yota1 said he may have a good used one in the shop.
Old Jul 19, 2020 | 05:03 PM
Warwagon's Avatar
Take it to a hydraulic hose shop. They should be able to make something for you. Bring in the whole assembly to show what you need.
Old Jul 19, 2020 | 09:59 PM
Co_94_PU's Avatar
What you are likely looking for are standard AN to JIS fittings. This lets you use common AN lline and ends to mate with the Toyota bits. Or change to a non Toyota filter.
Old Jul 19, 2020 | 10:08 PM
millball's Avatar
I'd have that proprietary Toyota fitting cut down and silver brased to an Aeroquip hose fitting in about 15 minutes. Aeroquip banjo on the other end. BAM!
Old Jul 20, 2020 | 11:13 AM
I'm going to the hydraulic hose shop today to see about having that done
Old Jul 20, 2020 | 12:44 PM
Damion812's Avatar
5 Year Member
I haven't investigated it too far yet but I think LC Engineering has som options for this.
Old Jul 21, 2020 | 07:55 PM
Hose shop crimped on a new line for 12.00, We'll see how it holds.
cikphrek
Feb 13, 2020 01:13 PM
Dbaker91
Jul 17, 2019 04:17 AM
shafner30
Sep 19, 2017 06:01 AM
Yota4Runner86
Dec 1, 2014 02:46 AM
Gamma_Hugo
Mar 11, 2014 02:17 PM
