How does the 22R-E prefer to drink Seafoam?
I've seen guys add it into the brake vacuum line on Youtube. I could probably also add it into the throttle body or other intake inlet. What is the superior method? The aerosol can into the vacuum line would be super easy. Does it ever make any sensors in the intake mad? I have an 86 btw.
Example:
Example:
There aren't any sensors in the direct flow of the intake or exhaust between the intake air temp and the oxygen sensor..
Follow up question, why do you think you need to do this in the first place?
Shaken, not stirred. LOL Anyways I would use on the the three(?) vacuum lines on the throttle body. The brake booster line is too big and you could potentially hydro lock the engine if you give it too much too fast.
The three vacuum tree and the brake booster port are both directly over the cylinder #4 intake runner. I doubt you'd get any Seafoam to cylinders 1 through 3. I'd say your best bet is somehow get it into the intake before the throttle body.
VwsandToys
Oct 5, 2019 04:02 PM
