KZN185 chassis
Roy, thanks for your reply .... but .... UK, EU, Japan etc specs are all slightly different and one spec does not meet all regulatory requirements of each market. I am trying to find out which reg's [eg emissions, brakes etc] the vehicle may be outside of for the UK otherwise the cost of modification would not make it worth keeping the vehicle [currently in Bosnia].
You might like to check out http://www.hiluxsurf.co.uk & http://www.milnerconv.co.uk.
What year model is your truck? There are also prados in there using the same engine (1KZ-TE). Europe already has the low-sulfur diesel so I'm sure emissions won't be a problem with the KZN185 (assuming that the engine is still in good condition). Brakes shouldn't be a problem either. You might like to check into the safety belts, srs air bags. Also, it would help if you can check out the host country's requirements. I believe that those info are available in the internet.
HTH.
89fourrunner
Feb 17, 2016 06:52 AM
FS[NorAtl]: FS: NYC 1987 4x4 22RE Engine and Auto Trans
TransAmBandit
Sep 20, 2015 06:08 PM
kelly1450
Sep 2, 2015 12:29 PM
