KZN185 chassis
Does anyone know if 4 runners with KZN185 chassis # are technically acceptable for registering in Europe? or how to find out what needs to be modified ?
thanks |
KZN185 Surf is the japanese-spec 3rd gen 4Runner but with the 1KZ-TE engine(3.0L SOHC turbo diesel, some are intercooled). There are lots of these in the UK, Romania, Russia, and Australia.
HTH. |
Roy, thanks for your reply .... but .... UK, EU, Japan etc specs are all slightly different and one spec does not meet all regulatory requirements of each market. I am trying to find out which reg's [eg emissions, brakes etc] the vehicle may be outside of for the UK otherwise the cost of modification would not make it worth keeping the vehicle [currently in Bosnia].
You might like to check out http://www.hiluxsurf.co.uk & http://www.milnerconv.co.uk. What year model is your truck? There are also prados in there using the same engine (1KZ-TE). Europe already has the low-sulfur diesel so I'm sure emissions won't be a problem with the KZN185 (assuming that the engine is still in good condition). Brakes shouldn't be a problem either. You might like to check into the safety belts, srs air bags. Also, it would help if you can check out the host country's requirements. I believe that those info are available in the internet. HTH. |
