swapping an 84 22R to an 85 22RE
Old Jan 3, 2020 | 05:11 PM
Daved_and_Confuzed's Avatar
Whats up dudes. I have a 1985 22RE that got sideswiped and found a 1984 22R with a knocking motor. since i have complete cars what would i need to swap over the fuelie to the 1984?
I remember researching a while back that i would need the efi dash or maybe just the efi gauges.
both are 5spd but the efi is hooked to a 2wd tranny and the 84 is 4wd. are the carb/efi flywheels the same?
Old Jan 11, 2020 | 09:18 AM
thefishguy77's Avatar
Swap the entire fuel system tank to engine put your wiring & dash cluster from your 85 into the 84. Would it be easier to just cab and bed swap the 84 stuff on to the 85? Then you probably just looking at pulling the wiring, ecu
& dash cluster from the 85 cab and installing it in to the 84 cab.
Old Jan 11, 2020 | 06:28 PM
Co_94_PU's Avatar
g
Yeah this.. All your intact EFI stuff onto the intact carb body, then repair any of the efi stuff you need to like damaged wires.. Essentially follow Terry's EFI to carb swap in the other direction.
Garrett Mamer
Aug 20, 2017 06:30 AM
iraqsucks
Jul 30, 2012 05:17 PM
myyota89
Dec 2, 2009 12:15 AM
harpen123
Feb 23, 2007 03:47 PM
85beatertruck
Oct 23, 2006 06:30 PM
