Post Your Tests Here Use this sectin for testing your signature files, and for testing pictures/avatars
Overheating 1990 pickup presists after fix attemp
Old Dec 26, 2019 | 07:20 PM
Larryfullsend's Avatar
I got this 1990 toyota pickup 3.0l v6 5 speed manual. After repairing some stuff here and there i got some temp plates. The truck overheated so i checked the thermistat as reccomended online. Thermistat was fine in the pot of boiling water. Rad cap for overflow spring was fine not to much resistantce. Rad fan seemed fine so water pump and clutchpack is fine. Flushed the rad and ran cleaner and water through the system yet still overheating the only thing i can think of is the block is clogged. Help is truely appriciated. Also just a final note heat is minimal if that matters in the cab. Oh and also it only overheats above 40 kilometers per hr
Old Dec 29, 2019 | 09:55 AM
joesgarage's Avatar
same here with my 1983 4X4 22R. Hope you get a answer for the fix. I’ve tried burping the system. still leaning towards hot on freeway speeds, but cool driving around town.
Old Dec 30, 2019 | 02:17 PM
joesgarage's Avatar
Gauge
what it showed today on freeway.
city driving
Old Jan 15, 2020 | 03:54 PM
tbh i timed the engine checked the waterpump and used 2 diffrent headgasket sealent my motor is royally f-d up i think its a major headgasket leak it started overheating on idle with the thermostat in but without the thermostat in i can drive it as long as i please but living in Canada i need heat and that also dosnt work
