r12 compresor oil
r12 compresor oil
1987 4runner a/c compressor oil capacity
using r12 to charge my system that was leaking.
I will remove the compressor and drain old oil
bur I need to know how much and what kind of
oil to replace
oil to replace
As far as adding oil, I would lean on the lower side of that recommended range since you probably still have some oil left in the compressor and in the lines, unless they were flushed. Also putting in a new dryer is always a good idea when opening system or if it had a leak.
a/c oil
there was no oil in the compressor, evaporator or lines. I added 7.5 oz's to the system and then charged it up.
nice and cold now. keeping my fingers crossed.
p.s. I found this sight helpful but hard to navigate.
