Site Feedback Please use this forum to provide feedback, suggestions on the site
Rear lights for yota with cut harness.
Old Sep 19, 2019 | 04:07 PM
Ram1's Avatar
Gentleman with flatbed with cut rear harness. I was going through the same thing. I figured out that the white/black stripe=ground for left side. ( Don't ground lights on frame, won't work )! Switches supply grounds. Red/black stripe=reverse. Green green=taillights. Green/black stripe=stop lights. Green/yellow= left turn. Black/white wire=ground for all three. The others go to right side. It took me a while to get this figured out but it works now. Hooking up a trailer plug is a bit more of a challenge because you can't use frame as ground. Have to use the truck grounds. I hope that this helps you out if you haven't already figured it out yourself. Toyota uses a different wiring system than US vehicles.
Old Sep 19, 2019 | 04:10 PM
Ram1's Avatar
Taillight harness diagram from online.
I'm trying to upload the diagram I found as to maybe help you out. It was a starting point for me.
Old Sep 19, 2019 | 04:14 PM
Ram1's Avatar
Image of the rear harness diagram for the lights.
The diagram is just a starting point as I stated. Some of the colors are right.
Ram1
Sep 16, 2019 12:59 PM
brando864rnr
7
May 4, 2006 08:21 AM
Eric DeCastro
Jan 9, 2006 01:10 AM
