Center-to-center bolt hole distance on 2nd gen 4Runner door panel armrest
I’ve done some searching but can’t turn up the answer... perhaps I haven’t hit the right combo of search terms. I’m trying to find out the distance between the armrest bolts the door panels on a 2nd gen 4Runner (or the truck). I’m interested if it’s the same as the 1st gen 4Runner. It appears that the distance on the 1st gen is 7-1/8”, as measured on my 87 SR5 with power windows. I’m planning to build new door panels and would like to use 2nd gen armrests if at all possible.
If I had a 2nd generation 4Runner, I would gladly measure the armrest bolt hole distance for you, but I do not have one.
Maybe @scope103 or @dropzone has the arm rests on their trucks that they could measure.
Last edited by old87yota; Aug 15, 2019 at 11:06 AM. Reason: Maybe one day I will get this member tagging thing right..... :)
Dang... so close. I may try to grab a 2nd gen armrest out of the pull-a-part and see if I can’t make it work somehow. I think I would find that preferable to the 1st gen armrest. More to come...
Math!
Math says that's probably not an accurate measurement.. Remember these use metric numbers .
7.75 inches=
7.75 inches=
196.85 millimeters
I don't recall seeing any fractional measurements in the frame geometry.
The good news is, your Toyota body is made of metal. You can add/remove metal in a metal structure super easy.
.. Yeah not alot of "direct" help, sorry. There are probably some usable photos in my album from when I redid the interior in the 94, you can get some dimensions off of with a decent image program.
Looks like we may have an answer from another thread that was started earlier today (8/16)... In “Identify Door Panels”, there is a picture of an 87 truck with the door panel from a 2nd gen 4Runner modified to fit the truck. When I say modified, he had to trim some of the panel at the sides, because the 2nd gen is a little longer of a door IIRC. The armrest from the 2nd gen 4Runner is there, so either it bolted right in or there was some modification on the door. Either way, I think I can make it work. Moreover than just swapping armrests, I’d really like to make a panel swap from a 2nd gen to my 1st gen. It’s definitely time to swing by the Pull A Part.
KyleT
10
Oct 21, 2006 07:36 PM
Figit090
25
Jan 8, 2005 02:18 PM
Ziltch
10
Sep 22, 2003 09:20 PM
