88 4Runner v6 auto trans , trucks stalls when put into drive or reverse
Old Jul 24, 2019 | 10:56 PM
4yota808's Avatar
Truck stutters while I’m park then stalls when put into drive and reverse
happend after I put in a new water pump
Old Jul 26, 2019 | 05:38 AM
DCMatt's Avatar
Check your vacuum connections. Maybe a hose was reconnected improperly or switched.
Or maybe it is not related to the water pump repair.
I had a stalling problem on my '88 4Runner 22re auto. Turned out to be a weak fuel pump. It would provide enough fuel to start the engine but stalled as soon as I put it in gear.
Old Jul 26, 2019 | 11:29 AM
akwheeler's Avatar
Check your work first, missed a ground wire? left a vacuum line off? knocked a plug wire off? connector not plugged in?
Old Jul 26, 2019 | 12:41 PM
akwheeler's Avatar
Oh, and check your timing marks, make damn sure you have all three marks lined up!
Old Jul 26, 2019 | 08:56 PM
4yota808's Avatar
That would cause it to stall? Srry newbie 👶🏻
Old Jul 26, 2019 | 09:02 PM
4yota808's Avatar
I’ll try n recheck,I hope it’s simple,I jus redid the fuel pump,and fuel filter
Old Jul 27, 2019 | 10:53 AM
akwheeler's Avatar
it can cause a number of issues, my logic is this: you said you replaced the water pump and then it began running like crap, on the v-6 the timing belt runs the water pump so you had to remove it. Check your work.
Old Aug 2, 2019 | 09:32 AM
4yota808's Avatar
Problem solved,timing was off big time,runs like a champ now thnx
Old Aug 2, 2019 | 09:58 AM
akwheeler's Avatar
The next round is on you!
Old Aug 2, 2019 | 06:48 PM
4yota808's Avatar
Lol for sure! Lmk if you’re ever in Hawaii
1988 Toyota Dolphin
Aug 14, 2024 10:52 AM
tonyusmc27
Nov 12, 2015 07:47 AM
SilentBounty
Jan 1, 2015 04:35 PM
dksardinha
Sep 16, 2014 09:38 PM
cweich
Jan 24, 2007 05:29 AM
