Ps idler pulley bolt
Old Mar 9, 2019 | 04:19 PM
Jf28142011's Avatar
So I'm finishing up bringing everything over from my old motor to my new motor and can't figure this out. The idler pulley from what I can see online is supposed to have a bolt through the bracket and into a threaded hole on the back of the pulley. Is this correct? Mine has a hole in the bracket not threaded and then just a nut on the back of the pulley. How's this setup supposed to work and what do I need to do about it. Thanks.
Old Mar 9, 2019 | 05:22 PM
old87yota's Avatar
What engine are you working on?
Old Mar 9, 2019 | 05:24 PM
Jf28142011's Avatar
It's a 22re
Old Mar 9, 2019 | 07:27 PM
old87yota's Avatar
Do you have a picture of what you have?
Mine looks like the one you describe you seeing online, with the pulley looking like this: https://www.yotashop.com/toyota-4run...ey-4435035010/
Old Mar 10, 2019 | 05:06 AM
Jf28142011's Avatar
Old Mar 10, 2019 | 05:09 AM
Jf28142011's Avatar
That's what I was afraid of. $148 that's insane. I guess someone lost the bolt and threaded piece and replaced it with a nut.
Old Feb 15, 2021 | 09:41 AM
jickson28's Avatar
Bolt size?
On my 92 pickup the head of the bolt is missing. Do you know the bolt size?
Old Feb 15, 2021 | 10:38 AM
87-4runner's Avatar
It's the same exact bolt as the 4 that bolt that bracket to the block under the dizzy...
you could just pull one of those 4 is over kill on that bracket.
Old Feb 15, 2021 | 01:22 PM
jickson28's Avatar
Thanks
Old Feb 15, 2021 | 01:35 PM
87-4runner's Avatar
Originally Posted by jickson28
Thanks
well, hold on, we may not be talking about the same thing...
I thought you were talking about the "bracket" bolt in the Pic...
but your actually talking about the bolt that goes thru the idler pulley?
That may be different... sorry
Old Feb 15, 2021 | 01:39 PM
jickson28's Avatar
Yes, I was looking for the adjustment bolt on the back side of the bracket/pulley.
Old Feb 15, 2021 | 06:32 PM
87-4runner's Avatar
Duh...I see the adjustment bolt missing in the Pic now....
you might try the 4Runner house in garland tx...
Old Feb 15, 2021 | 07:34 PM
scope103's Avatar
So far as I can tell, it's just an ordinary (flange head) bolt. If I had to guess, M10-1.25 x 100mm or so. Take the pulley down to your local Ace hardware, and ask for their assortment of metric bolts. Very carefully try an M10-1.25 to see if it fits. (The 100mm is really a WAG; try measuring how much throw you need first.)
92mn4runner
Jun 28, 2020 03:11 AM
greenmw
10
Oct 2, 2017 12:23 PM
Andre Remy
Nov 2, 2016 03:51 PM
arielb1
Jul 12, 2008 10:50 AM
Tigerstripe40
Oct 23, 2006 08:00 PM
