2.7 spark plugs
Old Jan 9, 2019 | 07:04 PM
RedYota93's Avatar
2.7 spark plugs
Odd question, but will the spark plug from my 22re swap over to my 2.7? Just picked up a 2.7 with a miss, and I have a set of spark plugs for my 22re sitting in the shop. Thanks
Old Jan 10, 2019 | 08:02 AM
75w90mantraN's Avatar
Dont you have a way to check specs in your shop? That member with the magic answer might be wondering this as well.
Old Jan 12, 2019 | 09:11 AM
Dirt Driver's Avatar
They're the same physical size, but I think the heat ranges are different. There are plenty of cross-references online. You can also spot an ignition misfire with a timing light if the 2.7 is a distributor model.
edward watts
Jan 16, 2018 01:41 PM
Co_94_PU
Jan 24, 2017 10:01 PM
rams
Jun 13, 2011 01:22 PM
mkgarrison5
18
Feb 7, 2007 08:35 AM
