2.7 spark plugs
Odd question, but will the spark plug from my 22re swap over to my 2.7? Just picked up a 2.7 with a miss, and I have a set of spark plugs for my 22re sitting in the shop. Thanks
Dont you have a way to check specs in your shop? That member with the magic answer might be wondering this as well.
They're the same physical size, but I think the heat ranges are different. There are plenty of cross-references online. You can also spot an ignition misfire with a timing light if the 2.7 is a distributor model.
