1989 W56C Trans 4WD Truck
Hey guys, great to be on this site for the first time. I've looked but can't find a way to explain my issue in a search so I haven't found the answer. Just picked up an 89 4X, 5 speed and the tranny will not shift. I can get it into what seems first and second (while car is off) but it is very very hard and then it gets stuck. Once stuck, I have to pull hard to get it out into neutral but it does not feel right. I pulled the tranny out today and would like some ideas.
thanks in advance.
thanks in advance.
Thanks for your reply. You are right. There are shavings in the tranny fluid. I’m getting it fully rebuilt since I have no history on it.
I see Marlincrusher, and Yota rebuilt trannys. Any specific recommendations?
Are you handy, or at least not easily intimidated? You could tackle it yourself, as it's not particularly complicated. Hopefully it's just bearings and seals. To start replacing gear sets can get expensive.
when I took off the drain plug, a synchro strut (dog) fell out. It looks to be a synchro issue. I might split it to see what else is going on in there, Not sure if I can get away with just new synchros.
The bitch about it is having a selection of proper circlips and possibly shims, as well as really nice gear and bearing pullers. You can grind the bearings off the shafts too, it's how I did mine in the transfercase that where really close to the gears.
Radchadtrinidad
Feb 17, 2018 11:15 PM
briandekeyser
Oct 2, 2015 09:37 PM
