Pre 84 Trucks 1st gen pickups
Wheel Cylinder Clearance
Old Nov 20, 2018 | 04:00 PM
selzzz's Avatar
Question Wheel Cylinder Clearance
I am currently replacing the rear brakes and bearing. I was able to get the bearing and collar low enough to get the c-clip on, but after doing so I realized that the wheel cylinder contacts the stud face preventing rotation and causing the backing plate to be uneven. I purchased the wheel cylinder from RockAuto and was hoping someone could tell me if the size of the wheel cylinder is wrong or if I did something incorrectly. The cylinder is mainly contacting the stud but is also only a few mm from contacting the back of the hub. I have made sure the stud is fully seated.
Old Nov 20, 2018 | 04:38 PM
millball's Avatar
It ought to be a simple matter to compare the wheel cylinder you removed to the new one.
I might have done that before I installed the new one.
Flash319
May 10, 2011 11:54 PM
ccannon222
Mar 14, 2008 04:15 PM
jim1000
15
Jan 23, 2008 11:43 AM
Chief_Yota
May 7, 2007 11:29 PM
04 Rocko Taco
Jun 29, 2006 11:00 AM
