Where is the ECU-IG Fuse on a 1994 Pickup
Old Oct 14, 2018 | 01:42 PM
ampload's Avatar
I can not find Where is the ECU-IG Fuse on a 1994 DLX Pickup. I looked at my Shop Manual and it showed that there was another small fuse box are to the left of the main fuse box in the lower left drivers side. where else should I look to find the ECU - IG Fuse Please Help.. Thank you
Do you see the ECU - IG Fuse in the diagram ? but when you see my FUSE BOX in the other picture... its not there ? so where did toyota re-locate it ? I dont see it.. does anyone know where it is,, Please Help
Old Oct 14, 2018 | 02:03 PM
ampload's Avatar
Picture of my Toyota Shop Manual ... it shows the little second box that holds the ECU-IG Fuse ... but I dont have this ... ( see the picture of my Fuse Box under the drivers side kick panel ... its different .. I need to find this fuse... my truck wont run with this blown fuse
Old Oct 14, 2018 | 05:46 PM
dropzone's Avatar
Fossilized
look under the hood on the passenger side wheel well, there is another fuse box with relays
Chandler Gourley
Oct 14, 2018 01:56 PM
Charchee
3.4 Swaps
Mar 20, 2017 07:37 PM
aceofsnett
Jan 10, 2012 08:56 AM
DiSperlonga
Nov 13, 2004 07:52 PM
