Where to set the timing without using the limp mode 93 pickup 3.0l
I assume that by' activating', you mean the jumpering of the TE1 to E1 terminals in the diagnostic plug???
The idle RPM must be very near to spec (not too high) and the TPS must be sending its 'throttle closed' signal to the ECU before the jumper will have its correct effect and then will show true base timing.
suckbaby
Feb 19, 2015 08:47 AM
