What engine oil do you use?
Searching thru this forum so far I have not run across any threads about engine oil. We all have to use it. Our machines need it to make us happy. So I have to ask what's in your crankcase? I am not an expert on the subject, just curious. I used Castor oil 10w30 in my 90 Toyota 3.0 V6 extra cab 4x4 since it was new. Did not seem to be any sludge build up other than emulsified oil when the head gasket blew. Been thinking about going full synthetic when i get thru rebuilding my engine. Any thots on the subject? Thanks for reading.
Yeah on rebuild dino is the way to go. Its fine on the engine and since you want to change early for the first couple changes why waste money on synthetic. I personally run Napa synthetic blend. Thats what we use on cars at work and have always liked the results. As of right now Valvoline makes Napa oil.
Yeah on rebuild dino is the way to go. Its fine on the engine and since you want to change early for the first couple changes why waste money on synthetic. I personally run Napa synthetic blend. That's what we use on cars at work and have always liked the results. As of right now Valvoline makes Napa oil.
Although expensive, some recommend Joe Gibbs Driven BR-30 Break-in oil for the initial break-in (up to 400 miles).
For "everyday use", I use the "Genuine Toyota 10W-30" oil I get from the dealer when I buy my Genuine Toyota oil filters.
Some people may say: why go to the dealer for oil when you can go to the parts stores and get "better" oil?
I buy the Genuine Toyota oil for convenience (I am already buying the oil filter), lower price compared to name-brand oil at the parts stores, and the current oil is several API oil classifications ahead of when my engine was made. In other words, the new oil is much better than what would have been on the shelves when the truck was new.
Switching to synthetic at a later date is up to you, but stick with conventional oil for the break-in period.
I have a 55 gallon drum of Castroil 25/40 that I have been using forever .
It gets used in everything from fresh rebuilds to engines with 200,000 miles plus
I am far to cheap to use synthetic having just one oil makes it hard to put the wrong oil in
If you don't use a break in oil... the rings will not seat properly against the cylinder walls and you'll use oil... and loose some compression... been there done that, even tried the old borax trick to try and break down the glazed cylinder walls... didn't work... eventually had to hone the cylinders re-ring and break in properly...
AppalachianOffRoader
Oct 11, 2013 02:29 PM
Amir904
20
Jan 15, 2005 10:50 AM
NX Tacoma
May 26, 2004 10:08 AM
alohatiger
Sep 3, 2003 09:03 PM
