Throttle body Coolant lines/Part numbers?
Does anyone have the Toyota part numbers for these? Mine is a 1989.... They are the tiny coolant lines that run under the and to the throttle body and IAC
I know I can put any old line in there and make it work. I want the formed lines. Like keeping it clean. Thanks
A 1989-what? You can get different engines, so far as I've heard.
But you can look up the part numbers yourself at any number of dealer sites.
https://parts.lakelandtoyota.com/sho...rimLevel=18292
Uh, probably not. You're likely to kink the "any-old" line, and then you have no (or not enough) coolant.
89 22re. Should have put that
people do it all the time, I have worked on more than one with funky make it fit lines.
so far I have looked on a few toyota OEM sights and haven't found those. But I will check out your sight.
people do it all the time, I have worked on more than one with funky make it fit lines.so far I have looked on a few toyota OEM sights and haven't found those. But I will check out your sight.
https://parts.lakelandtoyota.com/showAssembly.aspx?ukey_assembly=498963&ukey_make=1 060&ukey_model=15426&modelYear=1989&ukey_category= 21644&ukey_driveLine=6747&ukey_trimLevel=18292
Looks like I found under their EFI parts breakdown..
jfkell05
Apr 5, 2015 12:56 AM
Andrey
Jan 11, 2008 11:59 AM
