Turn motor for valve adjustment 3VZE
I am doing a valve adjustment on a 3VZE and to the point of turning motor to get to TDC #1 cyl. I cannot get to the harmonic balance bolt. Does the fan need to come out for this or is there a better way.
I read the bolt is 19mm is that correct?
or, remove the shroud and fan. there are four bolts to remove for the shroud, and the fan also has four bolts. you will need to loosen the alternator prior to removing the fan, though.
takes about 10 minutes to remove the shroud and fan. easier to rotate the engine from above, too. ymmv.
Blackbeardsghost
Jun 10, 2014 11:39 PM
brian2sun
13
Nov 14, 2011 09:05 AM
DeathCougar
Mar 24, 2007 11:33 AM
