1st gen 4Runner Hardtop refurbish
Old Apr 25, 2018 | 02:32 PM
hellgrunt5643's Avatar
Gents,
going to be working on refinishing the hardtop for the 88' runner i picked up the other day. Going to try and do it all myself, including re-uping the sliding windows which i have been able to find very little info on. Im working on it now, and will post some picks later. Any tips/tricks will be more than happily accepted!
Old Apr 25, 2018 | 09:08 PM
SomedayJ's Avatar
From other forum:
http://www.toyota-4runner.org/classi...s-removal.html
Old Apr 26, 2018 | 09:05 AM
RAD4Runner's Avatar
Originally Posted by hellgrunt5643
... including re-uping the sliding windows which i have been able to find very little info on....
IF my sliding windows were bad, I would totally consider modifying to make it work like the the gull-wing aka flip-up window here: https://goo.gl/images/twLGnX
Quick, easy and full-opening access to things inside from outside, and it would offer more protection from precipitation when open compared to a sliding window.
Old Apr 27, 2018 | 10:08 AM
Really like the full-wing idea! Here is were I’m at thus far. Pulled all windows to repaint the L trim and frames and clean and restore the rubber, also to redo the seals. Might take the window while they are out to have them darkened up a bit! Started in on the paint of the actual top. Did a full 5 coats(primer 3top and a gloss). Was going for a satin finish. Basically first run didn’t turn out like I wanted. The fiberglass was in bad shape and wouldn’t get a smooth finish. So sanded back down....and went with truck bed liner. It’s turning out much better and looking exactly like I want it to. I’ll post some pics of the bed liner tonight but here or some pictures of the dismantle.
Frame removed
Sliding window frame
Back window removed
Back windows
Inside the L trim in the sliders
Screw to remove glass and astragal from slider
Empty frames ready for paint
Old Apr 27, 2018 | 02:07 PM
RAD4Runner's Avatar
...Might take the window while they are out to have them darkened up a bit...
Good idea to tint them off the truck. Much easier to do by yourself.
While you have the body open, may I ask for dimensions of the lip where window is mounted and how deep it is recessed from main body? Would help with design/ concept of gull-wing window.
TIA!
Attached Thumbnails 1st gen 4Runner Hardtop refurbish-08855265_f849_4546_8190_b9755619c8e7_c62d022d09969c1794d22052115999eaf217c827.jpeg
Old Apr 27, 2018 | 05:32 PM
pretty equal at 9/16 all the way around. Also attached pics of 2nd coat on top
Old Apr 27, 2018 | 06:03 PM
RAD4Runner's Avatar
... Also attached pics of 2nd coat on top
Awesome! Thanks a lot and the paint job looks good!
Old Apr 27, 2018 | 11:09 PM
SomedayJ's Avatar
It looks like new. What is the bedliner you used?
Old Apr 28, 2018 | 12:02 AM
Rustoleum rattle can truck bed liner
Old Oct 22, 2019 | 06:24 PM
Glen Mizer's Avatar
Sliding glass, how do i remove them from the frame?
Gents,
How do i remove the sliding glass from the frame?
Old Oct 22, 2019 | 06:40 PM
Co_94_PU's Avatar
Brute force!
Unscrew the center channel, this allows you to flex the frame at the center and remove the glass. (You'll find this detailed in your FSM Body section.)
Old Oct 22, 2019 | 06:48 PM
Glen Mizer's Avatar
Thank you.
Thank you. I saw those screws, but wanted to verify before removing them.
Old Oct 29, 2019 | 12:02 AM
Glen Mizer's Avatar
Frame removed
Back window removed
Back windows
[/QUOTE]
Old Oct 29, 2019 | 12:04 AM
Glen Mizer's Avatar
Back window
Back windows
Are you glad you removed the back windows? Did you have any issues resealing them? What did you use ro seal them? I worry about damaging the existing weather strip because it is brittle.
redhanded
May 10, 2021 05:14 PM
crazycruzjr
Feb 11, 2014 01:23 PM
Snorkeldepth
May 24, 2006 07:38 PM
