New 22RE motor, white smoke
Old Nov 1, 2017 | 08:40 AM
samhain's Avatar
Got a '94 ext cab w/ a 22RE reman motor. I dropped it in, hooked it up, and from the beginning it smokes, white, not as thick as a blown HG, but thicker than cold weather condensation. Any thoughts? It has all the egr hooked up.
Old Nov 1, 2017 | 08:58 AM
scope103's Avatar
"White" smoke is usually water. Stick you hand into the smoke; is it wet? Oily? Sooty?
There is no "standard" blown head gasket, but white smoke suggests you have a water-to-exhaust leak somewhere.
Consider doing a coolant pressure test; you may be able to find where coolant is leaving the system.
Old Nov 1, 2017 | 09:16 AM
akwheeler's Avatar
Before the rebuild did you have a blown HG? Did you get coolant in the exhaust during teardown? Have you driven it long enough for it to warm up completely, if so did it still smoke after cooling down and restarting? Give it a chance to burn out any coolant or water that may have collected in the exhaust and see if it still smokes and like scope says, do a pressure test.
Old Nov 1, 2017 | 11:30 AM
samhain's Avatar
To scope: did the hand trick when it started, just wet. Will do the pressure test next. No visible leakage on the outside of motor. Thanks for the input.
To akwheeler: got the motor from power torque. Had it up to operating temp twice, probably not long enough. I will take for a drive and do the pressure test. Thanks for the input also.
Old Nov 2, 2017 | 04:12 PM
anndel's Avatar
white smoke could be from assembly grease
flg8r22
Sep 5, 2017 07:00 PM
Andy A
May 11, 2017 03:46 PM
no_3of4
May 10, 2017 02:05 AM
Hungrynomad
Mar 26, 2017 11:56 AM
ChrisJ
30
Nov 29, 2009 11:13 AM
