Hey folks. In my 1995 3.0 extended cab, I foolishly removed four bolts behind the starter in order to create more room to remove the starter. Once I removed the fourth and final bolt to what I thought was just a metal bracket, my truck dropped about an inch, to just enough that now I cannot get the holes back in alignment. I tried raising both front tires independently (haven't tried the rear yet) thinking that would create enough leverage to realign the bolt holes; unfortunately that didn't work. Anybody have any ideas about what to try?
Looks like the engine mounts from here. To get those back in you will have to raise the engine.
That's what I was afraid of! Too bad I gave away my father's cherry-picker a while ago. I'll have tackle this on Saturday and report back. Thanks for the quick response.
Put the jack under the engine pan and lift. Also there is a panel in the wheel well that you can remove to get more room.
Thanks for the advice, I'll do some poking around tomorrow to see what you mean. I'm doing this solo and outdoors, so every new step feels many times greater in difficulty than it should. Plus intermittent rain doesn't help.
Ah what a headache. I think when I did my starter I bought about three feet worth of 3/8th inch extensions and a swivel head and I took the starter out by sitting in front of the truck, in front of the bumper indian style. Similar situation with the back, I took it out way back. No additional bolts needed to be removed for clearance.
Removing the bolts wasn’t as much a problem considering everything else (working outside, zero mise-en-place, etc).
Getting that darn starter out and in was a total pain. Basically, the starter should be rotated opposite the direction that it’s installed. Raising the passenger side wheel provides inches of extra vertical clearance; I know this because my work light kept falling out of the wheel well when doing so. Pursuing greater horizontal clearance is what got me in this mess!
Solved! I was able to gently raise the motor with my floor jack by placing a 2x4 buttressed by 4x4 beneath, directly on the oil pan. I had to remove one 14mm bolt holding a shock that was blocking my access. Thank you to everyone who responded.
Oil-leak shaming! I was afraid of this! Decided to post the pictures anyway in order to possibly help others in the future. Oil leaks have been an ongoing problem for the entire 16 years I’ve owned the pickup. Love the truck regardless.
