2000 4runner won't turn over until you move shifter up and down
Old Oct 17, 2017 | 10:22 AM
Angelogeorge's Avatar
Question 2000 4runner won't turn over until you move shifter up and down
hey everyone new to the forums hesr but couldn't find and threads so heated my problem I have a 2000 Toyota 4Runner that I recently purchased so it was ran off a toggle switch leading straight to the starter relay because the guy I bought it from said that's the only way it would turn over or start when I put the relay back it will not turn over at all so I moved the gear shifter back and for several times because it was acting like a neutral safety switch problem I turn the key and now it turns over but still will not start keep in mind this truck was running and driving before but would die randomly so I tried reconnecting it the same way and now it will not start has no CEL or trouble codes please help me out asap on your ideas thanks
Old Oct 17, 2017 | 07:46 PM
RAD4Runner's Avatar
First things first... periods are free.
Check neutral safety switch? Got schematic? Got multi-meter?
