rebuild or buy new
Old Jul 11, 2017 | 07:34 PM
sweetoldyota's Avatar
Question rebuild or buy new
i have a 86 toyota pickup with a 22r motor carbed and the slip rings in the alternator are worn 3/4 of the way through. what caused this and cani use parts off a used one,are all the routers the same?
Old Jul 11, 2017 | 08:40 PM
millball's Avatar
I have not looked for Denso slip rings, but they're probably out there. Maybe Ebay?? I have bought several denso brush cassettes there.
I have rebuilt numerous Ford alternators, including new slip-rings. Some times you can press the new rings on and they will be concentric with the shaft, but if they are out more than a couple thousandths, the new rings really need to be made true on a lathe.
It is always good to rebuild components if you possibly can, it just makes you feel good to do it. and it always gives a you a better understanding of what is really going on with your machine.
As to what's the same??? I can't say. If you've got others take 'em apart and measure.
Old Jul 11, 2017 | 10:33 PM
5speedyota's Avatar
How much oil do you burn for fill up to fill up? Is this truck your daily?
Old Jul 11, 2017 | 10:41 PM
millball's Avatar
Huh????
Old Jul 12, 2017 | 12:32 AM
wyoming9's Avatar
Red face
They are confusing the slip rings with the piston rings !!
I had to think for a minute as well
Most likely have no idea what slip rings are !!
Old Jul 13, 2017 | 06:07 AM
my slip rings are in the alternator and no this is not my daily driver
