95 4runner a340h tranny question
In my searching of the forum, I did not find an answer to my question. There is a lot of information that has helped me come to a conclusion... so, here are the systems, what/where I believe the problem to be, and my question.
Rig: 95 4runner sr5 4wd. Motor - 3.0 3VZE, Tranny - A340H auto. 230k miles. Rebuilt motor (about 3k miles on it). Last owner claimed rebuilt tranny about 35k miles ago. That is unknown.
I went to a 4wd park, loads of fun. At one point I went down a pretty steep hill nose first. It was only after this event that I noticed my problem.
R does not work. When shifting into reverse, it engages, and the 4R will creep, as long as things are level, and without obstruction. Giving it gas only races the motor with out effect on reverse speed or ability.
In my searching, I learned that R and L have the same clutch pack and that one of the tests I can do is to try it in low and see if it behaves the same. Test was completed, L functions correctly.
Oh, and I did check trany fluid levels. It is full.
That has led me to believe that my problem lies with the valve body, with a bad/dirty check valve.
I believe that because it does engage in reverse, the reverse solenoid is not bad.
So, is my logic sound? or are there things I am not aware of that could be wrong?
And lastly, assuming that the problem is with the valve body, can I remove the valve body while the trany is in the 4R? or is that impossible? or a bad idea?
Any input/advise would be awesome... thanks!!
Replace the Soleniods. No change. I am still thinking it is in the valve body and am unsure what my next step should be. I have never worked on an auto trany and think my best bet would be to take it out and have a shop rebuild it... I do not want to go through the expence of a rebuild if the problem lies with the valve body and can be fixed without rebuilding the transmission.
When the budget allows put in a big trans cooler out front, to keep things cool. Auto tranny's hate heat. I like -6an stuff for trans cooler lines, very bullet proof.
Also since you found mud, try one of these.
http://www.ebay.com/itm/Transmission....c100005.m1851
