How to install Tachometer for 84 Toyota Pickup Camper 22R 4cyl
Want to install a simple tachometer or this 84 Toyota Pickup-Camper with 2.4: 4cyl 22R engine. Lots out there, including comments about being careful to replace (when hooking up to?) engine temp guage. Want to monitor RPM when going up hill here in Alaska
I bought a cheap digital tach off of eBay and I like it. Works fine for me. The instructions are pretty easy. I have seen a lot of people swap in SR5 clusters with no problem but I've tried TWO and I didn't like them. Speedo cable wined in one and I couldn't get the fuel to read in the other. If you just want RPMs a $30 eBay tach will work.
http://m.ebay.com/itm/2-Digital-Tach-Blue-LED-Display-Sm-Lens-9999-RPM-Warning-Light-w-Black-Cup-/222184421933?hash=item33bb393a2d%3Ag%3AfkEAAOSwLVZ VlA3m&_trkparms=pageci%253A51fd6267-34b3-11e7-a35c-74dbd1802c9c%257Cparentrq%253Aed30b3f515b0ab1ce996 161efffd4077%257Ciid%253A25
22R (2366cc) RN55L-KD3W - seen in mnfg tech manual where a RPM tester hooks to + and - battery terminals / then into - coil ... but other info browsed indicated Tach install with an EIS... so just looking to mount a small Tach on dash - looking for most efficient way...
Reason is to monitor steep ascents with this Dolphin Camper attached. Just purchased - with only 95,000 miles on rig - want to get a few more miles out of it.
bluAM2
Mar 17, 2017 08:59 AM
kevinfwtx
Nov 16, 2016 03:35 PM
bluAM2
Nov 4, 2016 10:59 AM
85EastTxToy
Aug 26, 2016 11:52 AM
