ISO '83 4x4 Rear Suspension SPRING SEAT
If you have a local spring shop near you try them. I just went thru this with my 1980. I used hillsborough spring and alignment about two hours away from me here in Florida
Any place that carries trailer axles and supplies will have all kinds of weld-on spring perches, center bolts, u-bolts, and the like.. They are usually fairly inexpensive.
There is a great resource in Tucson AZ for this material: Wheel equipment Inc. I have no interest in this Co., but i have purchased axles, springs and such from them in the past.
I would guess over the years I must have made 100 sets of these if not more
Any Fabricator should be able to make a set if you can measure your springs
I Never checked but I wonder if General Spring sells them
What is a spring seat? I came across this ISO a softer suspension. Maybe a actual spring seat would be easier than trying to choose which leaf springs and shocks will give me the 1978 fleet wood brougham Cadillac air ride I'm looking for
i wonder how many springs and what spring rate I would need for my drivers seat, although I'm thinking of getting new seats for my truck so maybe I should put this off
Spring perch, spring perch, Spring Perch, SPRING PERCH........ google it. Then go buy a Caddy if you want a Caddy ride.
you just gave me an idea , swap the body and air ride suspension, then add a spring seats .
spring perch
