barrel-key door locks
Old Oct 7, 2016 | 04:40 PM
robertd33's Avatar
newly purchased a '95 SR5
has anyone ever seen these? there are barrel-key door locks on both sides.
they're kinda neat, but it only came with 1 well worn key, so i'd like a replacement.
the only info on the key is "STAR-KEY".
barrel-key doors
Old Oct 8, 2016 | 06:26 PM
ewong's Avatar
woah
I haven't seen those in AGES...
The reason those barrel key locks exist, is that the Toyota key - when worn down to a "nub", will uh - basically open any Toyota truck door.....
Old Oct 8, 2016 | 08:01 PM
dropzone's Avatar
Fossilized
I would love to have those. Do they activate the electric locks?
D/S I turn unlocks driver door, double tap it and unlocks all 4 doors.
Any quality locksmith (probably gonna be spendy) should be able to make some barrel keys for you. I had some done for a lock a few years ago
Old Oct 8, 2016 | 11:54 PM
wyoming9's Avatar
As Drop zone stated any good locksmith has the tool and the blanks to make them.
I am curious just how the connection to the door linkage is made
Old Oct 9, 2016 | 03:15 AM
robertd33's Avatar
haven't opened the door to look, but it performs just like a regular key.
maybe somebody with a very special connection/resource, or a very ingenious/creative craftsman.
i haven't found anything of the sort on the internet.
related issues: i have a regular key for the ignition, which doesn't open the back door.
Old Oct 9, 2016 | 11:59 AM
dropzone's Avatar
Fossilized
that rear lock is easy to remove, you can pull the rear interior carpet from the tailgate, than you find a metal cover held on by 5 or 7 screws. the key switch is held in place with with a gold colored clip and you should be able to undo the wiring harness (i think it is a 3 wire terminal)
there is also a black rubber sheath type deal over the lock
crappy picture but you can kind of see it in the bottom of this picture
i added some extra wires for a rear mounted window switch
beorn
Nov 22, 2016 06:19 AM
DanOfDoom
Oct 8, 2016 06:22 PM
ThatOneMurse
Oct 8, 2016 10:38 AM
Capsulated
Oct 7, 2016 10:40 AM
Mike Farley
Sep 7, 2016 06:42 PM
