#4 cylinder not firing
Old Sep 5, 2016 | 04:50 PM
Tbarr419's Avatar
I have a 94 22re pickup and number 4 cylinder is not firing, I have spark, 195psi, 92 octane. Plug is wet. .030 decked off block. Adjustable cam sprocket, bigger injectors and egr delete, little bigger cam. Could I possibly have too weak of spark for the compression? Any tips would be appreciated. I have stock ignition (plugs,wires,distributor,coil)
Old Sep 6, 2016 | 06:43 AM
Terrys87's Avatar
I bought a truck one time that would fire the plugs but not ignite the fuel mixture. I ran some test on the coil and both test failed instantly. Check your Primary and Secondary resistance check and see what you get. Haynes has a great write up on testing the coil.
Have you tried swapping #4 injector to another cylinder? See if the problem moves or stays with the injector. Toyota did a poor job with the Injector wiring by using crimps in the harness. I have seen them corroded or even not connected when someone has tugged on the harness and broke the connection.
Old Sep 6, 2016 | 07:25 AM
fierohink's Avatar
You can also check your spark with a tester.
You can adjust the pin out until you lose spark to determine the voltage your ignition system is putting out, then compare that tithe service range in the FSM.
Old Sep 6, 2016 | 05:08 PM
Tbarr419's Avatar
alright thanks terrys87 I'll post my findings, it's been kicking my but
IMCOLOR
Jan 31, 2016 04:51 PM
scottxvanessa
13
Dec 4, 2002 03:22 PM
MonkeyElvis
11
Nov 18, 2002 05:35 AM
Brad
Sep 29, 2002 09:45 AM
Krash
Aug 17, 2002 08:20 PM
