'94 22re power steering idler pulley?
Old Jul 30, 2016 | 12:08 PM
CBCafe's Avatar
Where can I get his damn pulley without it being $150?
how is it even possible for a pulley to be this expensive
Old Jul 30, 2016 | 12:17 PM
CBCafe's Avatar
Can I just use an AC idler pulley for the power steering? It's $140 cheaper for some damn reason
Old Jul 30, 2016 | 02:47 PM
fierohink's Avatar
You could try to use s different pulley provided s few things are the same.
The shaft of both the pump and compressor would need to be the same.
The diameter of the pulley would need to be similar. Too small and your steering will be hard, too large and you could blow out things from over pressure.
Old Jul 30, 2016 | 03:03 PM
wyoming9's Avatar
Why has it failed ??
Unless the bracket has broken??
Bearings can be replaced quite cheap
I might have a few around
Old Jul 30, 2016 | 07:19 PM
CBCafe's Avatar
It's gone. I removed the belt a while ago and it must have rattled loose
Old Jul 30, 2016 | 08:05 PM
Charchee's Avatar
While you're waiting to find you one, check and make sure there isn't part of a bolt broke off in there.
Old Jul 30, 2016 | 11:33 PM
chuckross1957's Avatar
https://www.yotatech.com/forums/f116...pulley-197631/ The least painful solution (dollar wise) for most people is to buy a replacement bearing. I think it was around $20 at NAPA. Since you don't have the old pulley, there is a pn for a Dayco pulley in the posted link, but it is slightly larger and requires a longer belt.
Old Jul 31, 2016 | 01:53 AM
wyoming9's Avatar
Ok now we know your pulley is gone.
Just what else is missing ??
The mounting bracket ??
The adjustment hardware ?/
Be good to figure out just what all your going to need.
87tyota77
Apr 22, 2020 07:00 AM
DCMatt
May 21, 2019 06:24 PM
cgill87
Jun 22, 2016 05:07 PM
Casey7762
Jun 5, 2016 10:38 AM
sacramentoyota85
May 5, 2016 11:04 PM
