93 Toyota Pickup - RC, 22RE - Diagnosing Start Issue and Distributor Cap
Aloha,
I have been having an issue with my pickup and will do my best to describe it here and hopefully you all can shed some light on what the issue is. I have noticed in the last few months that after a heavy rain (my pickup gets parked outside on the street) my truck will turn over just fine but won't start in the morning. After I let it sit for a while it will start and the speedometer will stay pegged at zero and then work intermittently. Another symptom is that the engine, at idle, will slowly go down in rpms until it is just puttering along. My truck is manual and recently, on a super hot day, it died while in neutral between gears during a turn. I have recently replaced the battery and researching this issue leads me to believe that it may be the distributor cap but before I dig into that project I figured it would be best to reach out and ask you all. Earlier today I had the engine running and the hood open and brushed my hand across the middle terminal of the dist cap and got a nice shock. Any advice or help is greatly appreciated. I will post pictures in the morning if it isn't raining. Mahalos!
Update 1: going to pull the codes in the morning using the following how-to
http://4crawler.com/4x4/CheapTricks/...shtml#Late22RE
Will update as soon as i get done.
Update 2: pulled the codes (see pic below for setup) and the sequence is - I I I I I I I (~1s) I (~3s) I I I I I I I (~1s) I (~3s)...repeating = ODB1 code of 71 which is -
EGR VALVE MALFUNCTION
--EXHAUST GAS TEMPERATURE BELOW SPEC. FOR EGR CONTROL
--EGR SYSTEM
--EGR GAS TEMPERATURE SENSOR/CIRCUIT
Update 3: Added pics to this thread of the diagnostic setup and distributor cap, plugs/wires and ignition switch.
Update 4: Added pic with red arrow to mark where the shock originated from .
--EGR SYSTEM
not sure why you'd get shocked there, but with the hood up at night, you could look for arcing around the distributor cap/plug wires... if you've never pulled the cap, you'll want to do a visual inspection.
unplug the vacuum hose on top of the egr, block the hose, hook another hose up to the egr port and suck on the end of the hose while the motor is idling... it should stumble badly, maybe even die.
I disconnected the EGR hose you specified and connected a ~2ft. section of vacuum hose. Plugged the original hose and sucked through the 2ft section as you suggested which caused the engine to nearly die. What does this tell me?
Your coil wire is not pushed all the way into the cap!!
In fact that is a different coil wire .
By now it must have been arcing enough that the wire and the cap have some damage
That is the reason you got your little tickle !!
When was the last tune up ??
if you follow the hose back to its source at the front of the engine(?) i think that it starts out hooked up to a metal tube that in turn hooks up to a valve that operates on temperature? to put it another way, there are things that control when the egr is supposed to pass gas.
i think that if you disconnect both ends of that valve, you should be able to blow thru it when the engine is hot, but not when it's cold??? there is also a vacuum modulator, see the location pics for both here: https://www.yotatech.com/forums/f116...w-pics-159248/
it'll be similar to this: http://www.pirate4x4.com/forum/toyot...placement.html
need to dig up more troubleshooting steps on this, but what you've done so far is good news.
check out rockauto.com for the tuneup parts for your truck... might as well get plugs while you are at it.
Just pull the wire out of the cap look if the end of the wire and cap are arced (burnt)
Not knowing just what wire that coil wire is it should be pushed in as far as the other wires on the cap.
Good possibility the arcing was what caused your getting zapped .
Might be the cause of your stalling as well
The timing is only effected if you loosen the bolt holding the base of the distributor and turn the whole distributor .
Figured out how to temp. fix it
1. Distributor Cap
2. Rotor
3. Spark Plug Cable Set
4. Spark Plugs
Is there anything else? I would like to steer clear of re-doing the timing if necessary so if that means replace cap and not the rotor I am ok with it, if that mitigates the starting issue and address the rotor later. Thank you all for your help with this issue. Stoked to have made some progress.
Was reading another forum for a quick fix and someone suggested using a hair dryer on the dist. cap if it would not start. The cold start issue only occurs early in the morning when there is moisture/humidity/rain and when I use the hair dryer on the dist. cap/wire connections it works like a charm.
i would pull the cap in the morning, before starting it up, and see if there is any moisture inside the cap.... moisture inside the cap will cause arcing and cross-fire.
taloolarunner
Jul 20, 2002 05:51 PM
